How do I filter instruments out of a song?
Caseofgames
Post by Caseofgames » Mon Aug 31, 2020 10:25 pm
I want to filter out an instrument, and I have a sample of that instrument. Is it possible to use that sample to filter out an instrument?
Trebor
Re: How do I filter instruments out of a song?
Post by Trebor » Mon Aug 31, 2020 10:37 pm
Not in Audacity, nor any other DAW I know of.
Spleeter is your best bet: it uses AI,
see ... https://youtu.be/IHSGrGXp_oo
mafg1953
Post by mafg1953 » Tue Sep 01, 2020 12:12 am
Spectralayers Pro can Unmix Stems and does a pretty accurate job. The "other" category is a catch-all for what doesn't get split out in Vocal, Piano, Drums, or Bass.
Trebor
Post by Trebor » Tue Sep 01, 2020 9:18 am
Spectralayers Pro ...
...is only ~$300, (Spleeter is free).
