No limiter
Help for Audacity on macOS.
Humanguy
Operating System: macOS 10.12 Sierra
No limiter
Post by Humanguy » Mon Aug 31, 2020 9:21 pm
I've been doing some studying about audio processing and one thing I came across was the use of a limiter, which seems to me to be a rather important tool to have. In the manual it says that a limiter can be found under Effect, but my effects don't include a limiter. How do I proceed?
Screen Shot 2020-08-31 at 5.18.30 PM.png (104.08 KiB) Viewed 103 times
Screen Shot 2020-08-31 at 6.11.35 PM.png (242.79 KiB) Viewed 98 times
billw58
Re: No limiter
Post by billw58 » Mon Aug 31, 2020 10:27 pm
Go to Audacity > Preferences, then the Effects pane. Make sure "Nyquist" is checked.
Limiter is a Nyquist effect.
-- Bill
Humanguy
Re: No limiter
Post by Humanguy » Mon Aug 31, 2020 10:39 pm
Got it, many thanks.
