connecting to my desktop
Help for Audacity on macOS.
Goku
Post by Goku » Wed Aug 26, 2020 10:41 pm
Hi i'm have a new desktop Mac running Catalina 10.15.6 and audacity 2.4.2. I used to use back in the days this program, but it has changed a bit. Im having problems connecting my DJ mixer to the desktop. I have RCA cables connected from the session out on the mixer to the plug in the back of the desktop. I DONT KNOW WHAT TO DO TO HAVE IT READ IT ON AUDACITY. WHEN I GO TO THE RECORDING DEVICE IT ONLY SHOWS Imac Microphone, no other option. Record channel shows only 1 mono recording channel. Please if someone can help. I have tried looking in Youtube but no luck.
Re: connecting to my desktop
Post by kozikowski » Wed Aug 26, 2020 10:56 pm
The older machines had an actual stereo input connection.
The newer machines have....something else.
I use a Behringer UCA-202 to connect my sound mixer to the newer macs—or anything else.
Any of the variations will work. UCA-202, UFO-202, UCA-222.
The problem has been that Behringer shut down for the sickness and the adapters are hard to get.
Sweetwater Sound in the US is back-ordered on all of them.
I think the best you can do is a mono connection through the headset jack. Consult your instructions or Google your brains out.
Post by kozikowski » Wed Aug 26, 2020 10:59 pm
If you do get a sound connection, check that it's not Left-Only. That's what a headset connection generally does. It's not mono mix between Left and Right.
Post by kozikowski » Wed Aug 26, 2020 11:04 pm
Another nasty caution. These tiny USB Audio Adapters or similar aren't stereo, either. Most of them are mono microphone and stereo headphones.
Screen Shot 2020-08-26 at 16.00.50.png (22.01 KiB) Viewed 58 times
billw58
Post by billw58 » Wed Aug 26, 2020 11:09 pm
New desktop Macs do not have a line input. The jack you have connected to is the headphone jack.
-- Bill
