ACX Check Plug In
TJB
ACX Check Plug In
Post by TJB » Sun Aug 23, 2020 5:29 pm
I have the ACX Check plug in and, until recently, worked perfectly .... now, however, it works sometimes and sometimes not. For instance, it will only analyze a few minutes of recording. if that.
How do I download a new one?
Thanx for your help, Tom
Re: ACX Check Plug In
Post by kozikowski » Sun Aug 23, 2020 6:24 pm
That's the old one. This one should work better.
ACX-Check.ny
(4.39 KiB) Downloaded 21 times
Audacity > Tools > Nyquist Plug-in Installer
