Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
fbwaud
- Operating System: macOS 10.14 Mojave
Post
by fbwaud » Wed Aug 19, 2020 5:54 am
I'm trying to export a file with the following command and Audacity crashes consistently every time I hit save. I've tested these ffmpeg options working successfully directly in the terminal. This ffmpeg version was installed with homebrew.
Code: Select all
/usr/local/bin/ffmpeg -i - -c:a libfdk_aac -profile:a aac_he_v2 -ac 2 -b:a 32k "%f"
- audacity.png (197.33 KiB) Viewed 124 times
rayan008
Post
by rayan008 » Sun Aug 30, 2020 1:16 am
I am not an expert in this field But if you find the solution, I am interested
- Site Admin
Post
by steve » Sun Aug 30, 2020 10:25 am
fbwaud wrote: ↑Wed Aug 19, 2020 5:54 am
Try testing with a "32-bit float WAV" as the input file. Does that work?
