Win 10, Aud. 2.3.2
I realize this is a common problem, but after watching a bunch of videos I think I went & confused myself. Lost now.
Here's my set up: I've got a piano keyboard hooked up directly to the laptop to record a direct signal.
I'm using an audio adapter external stereo sound card with one end as a USB into the laptop & other end as a 1/4" male jack to the keyboard's headphone port.
The tutorials I saw didn't really address this setup. (not sure if it makes a diff')
Something about making the milliseconds a minus number under "Length & End of selection" area...
Be great if someone (esp. if you're a musician/ keyboard player) could point me in the right direction. Thanks!
Music recording/ latency
Rickenbacker
Re: Music recording/ latency
Are you having a problem?
There is always latency (delay) through the computer. For simple recording a few milliseconds is not a problem... It's going to be minutes, hours, days, before it's played back anyway.
The big issue is if you're monitoring yourself through the computer with a delay as you play the keyboard. If you can split the headphone output or otherwise directly-monitor yourself that solves the big problem.
If you are playing along with a backing-track, you'll need latency compensation to re-align the tracks after recording.Something about making the milliseconds a minus number under "Length & End of selection" area...
Rickenbacker
Ok, that worked, but only b/c I was lucky the keyboard had two output jacks. Otherwise, I mighta been screwed. Thanks!
