2 more questions about correcting latency
Help for Audacity on macOS.
Humanguy
Operating System: macOS 10.12 Sierra
Post by Humanguy » Tue Aug 18, 2020 8:38 pm
I've been going through the latency test print out and there are 2 things that are unclear.
1. Where is Software Playthrough? It's supposed to be turned off, but I can't find it anywhere in the manual.
2. This is probably a stupid question but I want to be absolutely certain: When holding the microphone in front of a speaker, does the original track need to be playing?
DVDdoug
Forum Crew
Re: 2 more questions about correcting latency
Post by DVDdoug » Tue Aug 18, 2020 9:08 pm
It's a checkbox under Recording Preferences.
When checking latency you should be playing the click track/rhythm track.
Post by steve » Tue Aug 18, 2020 9:14 pm
It is off by default.
As DVDdoug wrote, it can be found in "Recording" Preferences. (https://manual.audacityteam.org/man/rec ... ences.html)
It is also in:
"Transport menu > Transport Options" (https://manual.audacityteam.org/man/tra ... tions.html)
Yes. The idea is that you are recording, through the microphone, the track that is playing. You then adjust the "latency correction" so that the original track, and the newly recorded track are synchronised.
Humanguy
Post by Humanguy » Tue Aug 18, 2020 11:01 pm
Thanks Steve, that clears things up.
