Persistant crashing - I've tried everything...
Help for Audacity on macOS.
Re: Persistant crashing - I've tried everything...
Post by kozikowski » Fri Aug 14, 2020 8:06 pm
There is a video on the ACX instruction web page that recommends without question to capture your work on an external drive (the orange thing).
Screen Shot 2020-08-14 at 1.05.35 PM.png (145.58 KiB) Viewed 29 times
I recommend without question to not do that. Computer capture can cause a number of problems and an external drive just adds one more.
