Can you use the keyboard with the Time Shift Tool?
las14
Post by las14 » Mon Aug 10, 2020 1:13 pm
Is the mouse the only method for shifting a track with the time shift tool?
tia
las
Re: Can you use the keyboard with the Time Shift Tool?
Post by steve » Wed Aug 12, 2020 11:01 am
All of these tools are mouse tools: https://manual.audacityteam.org/man/tools_toolbar.html
To move a selection using the keyboard only, you could cut the selection, tab through to the Selection Toolbar and set the cursor to where you want the audio to start, then paste (as with the Time Shift Tool, there must be space in the track at the destination).
