Recording error message code 9986
Help for Audacity on macOS.
dmorga
Operating System: macOS 10.12 Sierra
Post by dmorga » Sun Aug 09, 2020 11:38 pm
Audacity version 2.4.2
Mac OS Catalina ver. 10.15.6
Mac Mini 2018
error message
Screen Shot 2020-08-09 at 4.34.19 PM.png (166.52 KiB) Viewed 312 times
system setup
Screen Shot 2020-08-09 at 4.19.47 PM.png (593.98 KiB) Viewed 312 times
Operation is random. Getting recording error message. See attachments pls
thx!
billw58
Re: Recording error message code 9986
Post by billw58 » Mon Aug 10, 2020 3:41 pm
What are you trying to do?
-- Bill
dmorga
Post by dmorga » Mon Aug 10, 2020 6:33 pm
Use Soundflower (or Blackhole) to route audio from Spotify, iTunes or other source into Audacity for recording.
billw58
Post by billw58 » Mon Aug 10, 2020 7:53 pm
I have no experience with Blackhole. There is this page on the wiki about using Soundflower.
-- Bill
billw58
Post by billw58 » Tue Aug 11, 2020 8:41 pm
OK, so I tried out Blackhole on my Catalina Macbook Air.
Following the instructions here, I set up a simple Multi-output Device in Audio MIDI Setup consisting solely of Built-in Output and Blackhole. Then set Blackhole as the System Sound Output. Finally I set Blackhole as the Input Device in Audacity.
I got some glitches the first time I tried it. First the recording cursor wouldn't move. Then I got the portaudio error message. I was possible not being rigorous enough - I had Audacity open while I was installing Blackhole and setting up the multi-output device.
I did Transport > Rescan Audio Devices and that seemed to clear it up.
So my suggestion (based on my limited experience) is that your multi-output device may be too complex. Change it to what they suggest and try again. That should be all you need to record system audio.
-- Bill
dmorga
Post by dmorga » Wed Aug 12, 2020 8:33 pm
Thx for the help.
Post by steve » Wed Aug 12, 2020 9:33 pm
Is the problem resolved?
dmorga
Post by dmorga » Thu Aug 13, 2020 3:48 am
Black Hole kept coming up randomly with the error message in my post. I went back to Soundflower as they are now posting compatibility with catalina.
So far, so good. I regret updating from Mojave. This is all a major pain in the ass.. thank you Apple
