Can I time shift two tracks at once? How?
I'm on Windows 10, Audacity 2.4.2
tia
las
Time shift tool
Re: Time shift tool
Select the two tracks using the Select Button in the Track Control Panel and then use the Time Shift Tool to move both tracks at the same time.
Re: Time shift tool
THANK YOU!!!! For anyone else as new to this as me, you need to hold the ctrl key down in order to select multiple tracks. That took me a few seconds to figure out.
Re: Time shift tool
Control and Shift keys work just like they do selecting anything else on your machine. Control selects one at a time and Shift selects everything between two selections.
Re: Time shift tool
Thanks again!
