I downloaded the LAME link suggested early in this chain:
Lame_Library_v3.99.5_for_Audacity_on_macOS.dmg
There did not seem to be any options for 32 vs 64 bit versions. Is there a full source for LAME versions that I could examine?
how do I add LAME to version 2.1.1 in OS 10.5?
carlsunshine
- Operating System: OS X 10.6 Snow Leopard or earlier
billw58
Re: how do I add LAME to version 2.1.1 in OS 10.5?
That is the 32-bit version.
-- Bill
-- Bill
