cannot load plugin
TheSwant
Operating System: OS X 10.10 Yosemite
cannot load plugin
Post by TheSwant » Mon Jul 27, 2020 6:39 pm
I'm on Windows 10 on a 64 bit processor using Audacity 2.4.1. I'm trying to use a plugin called Permut8, part of the Sonic Charge bundle. I can see the vst inside Audacity but I can't enable it. All I get is this error message. Is it somehow related to me being on a 64 bit machine?
https://www.pluginboutique.com/product/ ... 82-Permut8
failed to register.jpg (17.9 KiB) Viewed 142 times
mafg1953
Re: cannot load plugin
Post by mafg1953 » Mon Jul 27, 2020 7:35 pm
I'm not positive, but I think you need to have the 32 bit version of the plugin as Audacity is a 32 bit program. Maybe you are trying to read the 64 bit .dll.
Mike
DVDdoug
Forum Crew
Post by DVDdoug » Mon Jul 27, 2020 8:04 pm
Or... Some plug-ins don't support Audacity. Usually the plug-in developer supplies a list of officially-supported hosts. (Or with free plug-ins it's usually hit-or-miss and you just have to try it.)
TheSwant
Post by TheSwant » Tue Jul 28, 2020 12:48 pm
Thanks Mike. But to clearify: I'm already 64-bit machine using Audacity, a 32-bit program
mafg1953
Post by mafg1953 » Tue Jul 28, 2020 1:34 pm
TheSwant,
Sorry, I'm not sure I was clear in my post. Yes, I see that you have a 64-bit machine and Audacity is a 32-bit program, and that is fine. But I don't think Audacity can process a 64-bit plugin - I believe the plugins need to be 32-bit. And I think Permut8 comes in both 32-bit and 64-bit. So I was thinking you might be trying to access the 64 bit version of the plugin when it should be a 32-bit version. But as DVDdoug said, some plugins just don't work with Audacity.
Mike
DVDdoug
Forum Crew
Post by DVDdoug » Tue Jul 28, 2020 2:32 pm
Correct. Audacity (for Windows) ONLY works with 32-bit plug-ins.
