Audacity 2.4.2 Windows 10 64
I have learned my way through about 40 LP transfers. Wow what a program!
One problem i haven't been able to fix is the reverberation on some European recordings by Everest/Cetra from the 1950s. Reverb may be a bad description. It sounds like the recording may have been made in a theater or a large studio with no means of damping the sound. It is worse when only one person is singing and is not too bad when the orchestra is playing or a group are singing.
My description may be too nebulous to tell what it going on or the problem may not be fixable. Thank you for any help
Correcting Acoustics for "Tin- can Effect"
FatCattheGreat
Re: Correcting Acoustics for "Tin- can Effect"
There are de-reverb plugins ... viewtopic.php?p=380794#p380794
but IMO the artefacts they create would ruin a musical performance: more harm than good.
FatCattheGreat
