Waveform (db) not showing up as an option
Help for Audacity on macOS.
Longmont
Post by Longmont » Thu Jul 23, 2020 2:46 pm
Hoping someone can help me with this. I want to use noise gate, but I am not given the option to highlight waveform (db) in the side menu, as it isn't even listed there. The menu shows multi-view, waveform & spectrogram, but not waveform (db). Does anyone know how to fix this?
Re: Waveform (db) not showing up as an option
Post by kozikowski » Thu Jul 23, 2020 3:02 pm
Right-Click or Control+Click or Control+Tap the track's vertical scale (on the left)
Screen Shot 2020-07-23 at 8.01.42 AM.png (27.63 KiB) Viewed 211 times
