Audacity equalizer in other program (DAW)
jakub11
Post by jakub11 » Wed Jul 22, 2020 12:56 pm
Hello. Does a vst version of equalizer used in audacity exist. i must say that i really like how you can make many nodes manually to create really "thin" frequency filters. I did not see such posibility in my DAW's eq so i wonder if it would be possible to use the audacity one. Or if not maybe You know about another VST eq with simmilar posibility?
mafg1953
Re: Audacity equalizer in other program (DAW)
Post by mafg1953 » Wed Jul 22, 2020 1:50 pm
I haven't used it, but the Spline EQ free version has 4 bands while the paid version ($29) has up to 60 - which seems it might give you almost "unlimited" options for drawing your curves.
https://photosounder.com/splineeq/download.php
Post by steve » Wed Jul 22, 2020 5:33 pm
The free "ReaFir" VST from Reaper has a nice equalizer.
