Audacity can't find ffmpeg.55.64bit.dylib
Help for Audacity on macOS.
LarrySwanson
Post by LarrySwanson » Mon Jul 20, 2020 10:57 pm
I have followed the instructions on the Installing FFmpeg for Mac - https://manual.audacityteam.org/man/ins ... r_mac.html - multiple times, but Audacity can't find the FFmpeg library. Can anyone help me figure out what I may be doing wrong?
billw58
Re: Audacity can't find ffmpeg.55.64bit.dylib
Post by billw58 » Tue Jul 21, 2020 12:22 am
Which version of Audacity do you have? What version of macOS? Note that the 64-bit version of FFmpeg requires a 64-bit version of Audacity (2.3.1 or later)
Please start Audacity then select Help > Diagnostics > Show Log. Click the Save button to save the log into a text file. Copy and paste the contents of that text file into a reply here.
-- Bill
LarrySwanson
Post by LarrySwanson » Wed Jul 22, 2020 12:33 am
Thanks for the quick reply.
I'm running Audacity 2.4.2 on a MacBook Air running macOS 10.15.6. Screen shots attached of what I'm seeing as I try to help Audacity find the FFmpeg file.
The lame_64bit_osx.pkg installation appears to go just fine.
When I go to Preferences > Library > Locate, navigate to the file and click "OK" I still see "FFmpeg library not found" regardless of how I navigate to the file.
When I go to Help > Diagnostics > the Show log link is greyed out.
after running lame_64bit_osx.pkg
Screen Shot 2020-07-21 at 5.17.29 PM.png (98.78 KiB) Viewed 652 times
error when I try to import .m4a file
Screen Shot 2020-07-21 at 5.19.07 PM.png (65.9 KiB) Viewed 652 times
display at Libraries > Locate
Screen Shot 2020-07-21 at 5.19.41 PM.png (80.45 KiB) Viewed 652 times
Screen Shot 2020-07-21 at 5.19.51 PM.png (134.23 KiB) Viewed 652 times
billw58
Post by billw58 » Wed Jul 22, 2020 3:10 am
Look at your first screen shot. You are using the installer for LAME, not FFmpeg.
-- Bill
LarrySwanson
Post by LarrySwanson » Wed Jul 22, 2020 5:16 am
D'oh! Thanks.
