Help needed! I recorded 3 episodes last weekend and edited two of them. I returned to the 3rd one today and this occurred (please see screenshots below). Is there any hope to recover this?
Disclaimer: I did clean up all my files and moved it from the original location it saved to from the desktop to a folder on the desktop - did not delete any of the extraneous files that come with the download.
"Cannot load file" error pop up
comfortkills
- Operating System: macOS 10.12 Sierra
- Attachments
- Screen Shot 2020-07-19 at 8.41.21 AM.png (133.36 KiB) Viewed 20 times
- Screen Shot 2020-07-19 at 8.41.44 AM.png (217.51 KiB) Viewed 20 times
Re: "Cannot load file" error pop up
There should be a "_data" folder:
To recover the project, you need to find that folder and ensure that it is in the correct place (as shown above)
