Audio channel count 1,must be 2 (Stereo)
slavik
Post by slavik » Sat Jul 18, 2020 4:31 am
Hello everyone,
I have a problem uploading my wave file.
Track Problems
The following track(s) have errors:
SOFIA.wav:
Bit depth is 32 bits, must be 16 or 24 bits.
Audio channel count is 1, must be 2 (Stereo)
Can any of you help me solve this?
Thanks in advance.
With kind greetings.
gilbert :?
Trebor
Re: Audio channel count 1,must be 2 (Stereo)
Post by Trebor » Sat Jul 18, 2020 7:57 am
When you export (save) there is a drop-down menu where you can select the bit depth ...
"WAV (Microsoft) signed 16-bit PCM" is universally accepted.
If you need to make a mono recording into 2-channel, (a/k/a dual mono).
Duplicate the track, (select the track, then press "Ctrl"+"D").
Then join those two identical tracks to make a "stereo" pair, see ...
https://manual.audacityteam.org/man/spl ... racks.html
slavik
Post by slavik » Sun Aug 02, 2020 11:08 pm
Thank you kindly for your help. When I play my song Sofia.wave 16 bit(705 kbps) in audacity, the green levels of both recording channels move. This indicates that a stereo song is playing.
But when I upload my music file Sofia.wave to the music platform Amuse, I get the following message:Track Problems The following track(s) have errors:
SOFIA.wav:Audio channel count is 1, must be 2 (Stereo).
What's going on here? Is this an error of the music platform Amuse or is it a mistake in my song?
See the attachments.
Please advise you on this.
Thanks in advance.
Kind regards
Gilberto
Sofia mono naar stereo 2 aug 2020.png (85.17 KiB) Viewed 210 times
Sofia mono naar stereo 2 2 aug 2020.png (138.45 KiB) Viewed 210 times
Sofia mono naar stereo 3 2 aug 2020.png (138.26 KiB) Viewed 210 times
Sofia mono naar stereo 4 2 aug 2020.png (91.33 KiB) Viewed 210 times
slavik
Post by slavik » Mon Aug 03, 2020 1:11 am
Meanwhile, I followed your guidelines and after duplicating and " making a stereo track " has managed to upload my song on the Music platform Amuse.
A million thanks for your help, I am very pleased with the result through your cooperation.
Best regards,
Gilberto :D
