I tried to import an m4a (AAC) file into Audacity a few minutes ago. But no joy.
I downloaded a converter program (Free Mp3 Wma Converter - Lite Edition 1.6) and it seems to do the job just fine, but I was wondering what in the way of sound quality is sacrificed when converting files in this way?
Pete
File conversion
Pete Porchos
Re: File conversion
It depends entirely on what you converted them to and how the AAC was made. If you converted to 48000/16bit WAV then there is no further damage, and there was minimal damage on the AAC -> PCM step.
If whoever made the AAC file did a good job, then you win.
If the AAC creator did a sloppy job and you converted to MP3, then you lose. I would bet there is significant damager to the sound.
Both MP3 and AAC are slider-based, lossy compressors and both create damage when they work. Fast--Bad Quality--Small Files on one side of the export slider and Slow--Very Good Quality--Big Files on the other. Pick your setting(s).
