Female voice quality - equalisation advice appreciated
Bert Coules
- Operating System: Windows 7
Re: Female voice quality - equalisation advice appreciated
Great, thanks. I'll have a play.
That's dangerous. This is a directional microphone. Its desirable characteristics work straight in front of it. Any other orientation and the volume goes down and the tonal quality changes. More importantly, the sensitive direction of the mic doesn't vanish, you just point it to somewhere else in the room. We already have trouble with it picking up sound other than the performer. It should always point at the performer.I thought you meant leaving the mic where it is but rotating it some 30 to 40 degrees on its axis.
You don't have to go full oblique, If you find that a partial orientation works, then use that. Again, most P Popping goes straight in front of the/your/her lips. Don't put the microphone there.
There is a caution about that. Step one in mastering—Filter Curve—also removes bass tones (on the left) It's not good to have two different effects fighting each other.how much bass was removed.
Only judge the sound quality after the final action, and it's super important to listen in a way you trust. There's nothing quite like delivering a product with sound damage that only your client can hear.
And in case this gets lost, the goal is to accurately reproduce the talent's voice. No extra points given for the large number of effects used.
Bert Coules
Yes, I do see the distinction. Thanks.kozikowski wrote: ↑Thu Jul 16, 2020 10:25 amThat's dangerous. This is a directional microphone. Its desirable characteristics work straight in front of it. Any other orientation and the volume goes down and the tonal quality changes... It should always point at the performer.
"Step one... Filter Curve"? It's possible that I'm missing out a vital mastering stage. What I've been trying (and I think I got the sequence from this forum, though I may be mistaken) is this:There is a caution about that. Step one in mastering—Filter Curve—also removes bass tones (on the left) It's not good to have two different effects fighting each other.
1. Effect: RMS Normalise (-18dB)
2. Effect: Limiter (-3.00dB)
So unless I'm misunderstanding something (which is of course entirely likely) Trebor's recommendation would be the first and only bass cut.
It's possible you're missing all of them.It's possible that I'm missing out a vital mastering stage.
It's a Mastering Suite. A harmonious grouping. Shouldn't take them out of order, add any, or leave any out.
Limit to -3.5 rather than -3.0 because the conversion to MP3 can cause volume errors and violate the ACX Peak specification.
Filter Curve is there to keep microphone USB errors and room rumble from throwing off Loudness Normalization.
These are from the mastering instructions.
Bert Coules
True. I don't know where I got my sequence from.
I'll work through your list and the settings you give and see what that does.
Bert Coules
And here is the result, still as a WAV file. The bass boom is still evident though perhaps not quite as much. Following Trebor's advice perhaps I'll experiment slightly with the filter curve setting, though a new mic position might presumably also have an effect in that area.
. And the same but with more bass roll-off as the first stage, in line with Trebor's recommendation:
Pretty much. You show limiting to -3dB which is dangerously close to the limit and likely to trigger a violation. The Loudness setting at -18dB is at one end of the allowable range -18dB to -23dB.Not all, surely?
The numbers in your post are the absolute limits, not the goals. It's hard to deal with the blizzard of numbers, techniques, and tricks, but you are replacing the recording engineer and entertainment producer. If you ever wondered what they did.....
Audiobook Mastering is not the only way to do this. One poster was able to bring performances in using completely different tools, but this collection has worked very well.
"ACX has accepted my book!!"
That seems good. I think enough of the errors are gone. Go with that.COWS mastered 16th.wav
Did I post how to send a test to ACX?
Points given for making it through in one breath.
I can't do it, either.
My ACX Test was about having an absurd conversation at a lunch counter between persons one and three. We were falling apart throwing lines at each other, but the person in the middle (scrambled eggs and toast) wasn't reacting at all. Person #2 would make a terrific poker player.
