No plug in folder
Help for Audacity on macOS.
helpme11111
Re: No plug in folder
Post by helpme11111 » Tue Jan 19, 2021 9:10 am
Hello,
I am currently running macOS Big Sur (11.1). I have downloaded audacity and wanted to add plugins, but there is not plugin folder to be found. I used the Finder to try and look for a possible location for the plugin folder, but have found no such evidence of it existing.
Wondering if anyone has any idea where to locate it, or if the new update, plugins aren't to be added? I don't know, at this point, I'm just guessing what is possibly malfunctioning. :?
Thank you in advance!
Post by steve » Tue Jan 19, 2021 10:43 am
What sort of plug-in? The installation instructions depend on the type of plug-in. See: https://manual.audacityteam.org/man/ins ... _os_x.html
