Can't install plugins
Help for Audacity on macOS.
NateDawg
Post by NateDawg » Mon Jul 06, 2020 4:25 am
Hey guys, I am trying to install the ACX check plugin. Downloaded it, and placed it in the appropriate folder as pic'd below. Yet it won't show up when I go to Analyze-Add/Remove Plugins.Tried it with both the .txt extension and without, and works neither way. Appreciate any insight.
Screen Shot 2020-07-06 at 12.22.34 AM.png (1.09 MiB) Viewed 114 times
Re: Can't install plugins
Post by steve » Thu Jul 23, 2020 1:18 pm
Use these instructions to install Nyquist plug-ins (ACX check is a "Nyquist Plug-in"): https://manual.audacityteam.org/man/ins ... st_install
Also, ensure that you have the latest version of ACX Check (it was recently updated): https://wiki.audacityteam.org/wiki/Nyqu ... #ACX_Check
