Audacity abandons .webm ?
Help for Audacity on macOS.
adambrower
Operating System: macOS 10.11 El Capitan
Post by adambrower » Fri Jul 03, 2020 4:35 am
Audacity 2.3.3 no longer recognizes the webm format. Current ffmpeg installed, everything updated. Paths are good. Is anyone at the project looking at this? the webm format is ubiquitous now. Until 2.3, Audacity recognized .webm without a gripe.
Is this an intentional decision by the team to no longer support the format?
Someone else posted the same notice last year. Views: 1170. Replies: 0
Is anyone reading the forum, even?
Re: Audacity abandons .webm ?
Post by steve » Fri Jul 03, 2020 9:07 am
Given that there's around 99.9% response rate, I think it's obvious that your question is unfounded.
Webm is a "container format".
Audacity still supports Webm, but only if FFmpeg has decoders to match the encoding used inside the Webm container.
There's a webm file here and I can import the audio using Audacity 2.4.2 on Linux: http://dl5.webmfiles.org/big-buck-bunny_trailer.webm (file originally from bigbuckbunny.org)
adambrower
Post by adambrower » Sat Jul 04, 2020 10:01 pm
For Linux, maybe, but not OSX. That's why I posted here in the forum for "Audacity 2.x.x on macOS 10.4".
I'm running current ffmpeg, and can longer open the .webm format in 2.3.3. In 2.2, no such problem arose. If someone could look into this, it would be appreciated. Mine is not the only report.
Post by steve » Sun Jul 05, 2020 12:40 pm
Audacity 2.3.3 is an old version. The current version is Audacity 2.4.2.
https://www.audacityteam.org/download/mac/
After updating to 2.4.2 you may also need to update FFmpeg.
I would recommend using the PKG version "ffmpeg_64bit_osx.pkg"
https://manual.audacityteam.org/man/ins ... r_mac.html
I've just tested on a fully updated Mac Mini with Audacity 2.4.2 and ffmpeg_64bit_osx.pkg, and the file "big-buck-bunny_trailer.webm" was successfully imported.
