Special Delete?
Help for Audacity on macOS.
Special Delete?
Post by kozikowski » Wed Jul 01, 2020 3:47 pm
I'm going to carefully select something on the timeline. In one keystroke (or two), delete everything else. Leave it right there in time.
Photoshop has Select and Invert the Select—select everything else.
Re: Special Delete?
Post by steve » Wed Jul 01, 2020 4:05 pm
Windows / Linux: "Ctrl + T"
I'd guess that on Mac it's "command + T".
"Edit > Remove Special > Trim Audio"
https://manual.audacityteam.org/man/edi ... trim_audio
Re: Special Delete?
Post by kozikowski » Wed Jul 01, 2020 7:47 pm
It's Command+T
Screen Shot 2020-07-01 at 12.44.10.png (26.33 KiB) Viewed 60 times
Screen Shot 2020-07-01 at 12.44.25.png (22.92 KiB) Viewed 60 times
