Skips/Clicks That Come and Go
mafg1953
Post by mafg1953 » Fri Jun 26, 2020 1:52 pm
Hi,
I'm using Win 10 and Audacity Ver 2.4.1.
I am noticing that when I am listening to audio during my editing process, that I sometimes hear a short series of 2-3 clicks or hesitations in the playback. If I stop the audio and replay that same section again, it sounds fine.
I'm not sure when I started hearing this - but I believe it has been off and on even with Version 2.3.3.
I haven't thought much about it as the audio is actually clean, but just wondering if this happens to anyone else and if there is an explanation for this issue.
Thanks,
Mike
"Nothing worth knowing reveals its secrets easily"
mafg1953
Re: Skips/Clicks That Come and Go
Post by mafg1953 » Fri Jun 26, 2020 7:41 pm
Okay, I think I narrowed it down to my headphones - I'm using Beats Bluetooth Noise Cancelling headphones. I tried my iPhone headphones and there were no skips or clicks. So I'm going to look at getting the Sennheiser HD 280 Pro based on several reviews.
Mike
