Channel order when exporting to AC3 5.1 surround
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
DrLex
Post by DrLex » Wed Jul 08, 2009 1:24 pm
I'm trying to make my own AC3 surround track. I have 6 separate channels for Lf, Rf, C, Ls, Rs and LFE respectively. Can anyone tell me in what order I should put these channels to get them assigned correctly when exporting to an AC3 file?
I could search the correct channel order through trial & error when I have access to a surround system, but it would save me a lot of time if someone has done this before and could share their experiences...
Edit: adding '5.1' to make this topic easier to find in search engines, because I couldn't even find my own post while searching for stuff like "5.1 channel ordering" ;)
Re: Channel order when exporting to AC3 surround
Post by kozikowski » Wed Jul 08, 2009 2:09 pm
How sure are you it doesn't let you assign them at the export step?
DrLex
Post by DrLex » Wed Jul 08, 2009 4:31 pm
kozikowski wrote:How sure are you it doesn't let you assign them at the export step?
It lets me assign channels (if 'custom mix' is enabled in the preferences), but the target channels just have numbers, not very helpful.
Anyhow, I did the trial & error thing, and the correct ordering appears to be:
1. L front
2. Center
3. R front
4. L surround
5. R surround
6. LFE
takm
Post by takm » Sat Aug 08, 2009 3:14 am
Just to complement, i think if you try to export to OGG it is:
1. Left
2. Center
3. Right
4. LS
5. LFE
6. RS
DrLex
Post by DrLex » Sat Aug 08, 2009 2:02 pm
It seems that the ordering of the AC3 channels has changed between Audacity 1.3.7 and 1.3.8 :roll:
The new ordering is:
1. L front
2. R front
3. Center
4. LFE
5. L Surround
6. R Surround
1.3.8 is useless anyhow because it refuses to save .aup projects. Time Machine to the rescue...
Post by kozikowski » Sat Aug 08, 2009 11:48 pm
<<<1.3.8 is useless anyhow because it refuses to save .aup projects. Time Machine to the rescue...>>>
So you're on a Mac. Have you been following all the troubles 1.3.8 has on Macs? Try the latest build.
http://forum.audacityteam.org/viewtopic ... 37&t=11534
Post by Gale Andrews » Sun Oct 03, 2010 5:50 pm
DrLex wrote:It seems that the ordering of the AC3 channels has changed between Audacity 1.3.7 and 1.3.8 :roll:
1. L front
2. R front
3. Center
4. LFE
5. L Surround
6. R Surround
Whatever may or may not have happened, that ordering is correct for 5:1.
