Audacity 2.4.1
Have created several tracks of MP3 music and want to move them to a DVD. Does Windows 10 have an app for burning DVD and CDs? What is it called? Failing an internal Windows 10 app what would you all recommend for this job? Again, I know, a simpleton question but I just can't seem to find an app in Windows 10. Thanks for your kindness.
Creating a DVD using MP3 files
FatCattheGreat
Re: Creating a DVD using MP3 files
Do you have a DVD/CD burner? A physical drive?
Windows Media used to be able to do this as part of its regular tools.
