Stability on Catalina?
Current Mac Version 10.14.6
Audacity Version 2.3.2
I'm an Audacity donor and VO talent and love Audacity but have been reluctant to update the Catalina as my current version of Audacity does not work on Catalina. I cannot afford to experiment or do work arounds. Is version 2.4.1 rock solid to download for Catalina? Thanks, - Pete
billw58
Re: Stability on Catalina?
Audacity 2.3.2 works on Catalina.
-- Bill
-- Bill
2.3.2 works...
Are you super sure about that?
https://www.audacityteam.org/macos-10-1 ... -audacity/
Crosses in support was the reason 2.4.1 was rushed out.
If you're on Mojave or High Sierra, I'd probably stay there for a while.
Thanks KOZ. I made the mistake of upgrading to Catalina and then discovered 2.3.2 did not work on Catalina so I had to cancel booked work to spend a day getting Mojave back. I think I'll stay with Mojave awhile longer as I can't afford to be down another day. Thanks for your input.
The recommended version for Catalina is now Audacity 2.4.2 https://www.audacityteam.org/download/mac/
billw58
You're right, 2.3.2 won't access the microphone but otherwise runs.
-- Bill
By what method?spend a day getting Mojave back.
waxcylinder
And 2.4.2 runs fine and is stable on my Macbook Pro with Catalina 10.15.5steve wrote: ↑Fri Jun 26, 2020 4:33 pmThe recommended version for Catalina is now Audacity 2.4.2 https://www.audacityteam.org/download/mac/
