Hit "Record" - Nothing Happens
Re: Hit "Record" - Nothing Happens
Post by steve » Sun Mar 21, 2021 5:24 pm
giancarlodavis wrote:
Sun Mar 21, 2021 5:18 pm
I am having the same problem.
Probably not the same. Are you using a Blue Yeti like bluespapa?
If your problem is still regarding your Fender amp, I posted a reply here: viewtopic.php?p=388150#p388150
Post by kozikowski » Sun Mar 21, 2021 5:54 pm
Does Audacity still default to Preferences > Recording > Overdub [X] On? Doesn't that mean both the recording and the playback services have to be in perfect working order?
Does the Audacity program reinstall still default to saving old preferences and settings?
What does that screen look like where it asks you if you want to trash the preferences during a reinstall?
