Create stutter effect popular in hip hop
Re: Create stutter effect popular in hip hop
Post by steve » Tue Jul 14, 2009 4:30 pm
Attached is version 1 of my "Stutter" effect.
Unzip it into your Audacity plug-ins folder and then restart Audacity. It should then be listed in the Effects menu.
I am writing a more flexible "version 2" of this effect, so any feedback on this first version is most welcome.
Steve
esp_stutter.ny.zip
(630 Bytes) Downloaded 349 times
itaintlegal1
Post by itaintlegal1 » Wed Jul 15, 2009 12:58 am
Trebor wrote:
itaintlegal1 wrote: do you have the original audio file
I attached the audio as a wav in a zip file (see the attachment on my previous post).
Zip files are the only way to post audio on this forum without linking to an external filesharing site.
BTW my attempt is a very rough approximation.
thx but like was there an audio file before u altered it into the one u attatched? or was the whole file jus generated from the plugin
itaintlegal1
Post by itaintlegal1 » Wed Jul 15, 2009 1:45 am
stevethefiddle wrote:Attached is version 1 of my "Stutter" effect.
Steve
holy shit dude tht is awesome. i think tht is exactly wut im looking for. good luck on the next version, keep up the great work
itaintlegal1
Post by itaintlegal1 » Wed Jul 15, 2009 1:52 am
Steve
also if ud like to test out ur plugin to compare the effects, im attaching the sound heard in the video befor it was altered. i would of done this earlyer but i just found it. i think the only difference may be change in pitch or tempo, which can be done already in audacity
Famous_DJ_Tool.zip
file
(44.47 KiB) Downloaded 130 times
Trebor
Post by Trebor » Wed Jul 15, 2009 10:53 am
itaintlegal1 wrote: thx but like was there an audio file before u altered it into the one u attatched? or was the whole file jus generated from the plugin
Entirely generated from David R. Sky's (free) ring-modulator plugin ... http://www.shellworld.net/~davidsky/ringmod.ny
Your DJ_tool sample is nearer the video sound starting at 0:08 if modulated with a triangular waveform
(see the attached zip which was done with Mr Sky‘s ring-modulator plugin).
[Still think my original attempt, although rough, is nearer sound on the video which has simultaneous rising and falling tones].
Famous_DJ_Tool_now_triangle_ringmoded_#2.zip
(248.86 KiB) Downloaded 91 times
djfulfill
Post by djfulfill » Fri Jul 17, 2009 7:01 pm
yo it's really easy, just find the part you want to stutter, use repeat, choose how many times you want the sample to repeat, on mine i chose 4, grabbed just the "d" in dj so you get a this is a dddd dj fulfill exxlusive
here is a link.. i just found this out myself.. hope i have helped..
http://www.zshare.net/audio/627984119b3a90a6/
anybody got radio effects.. soundbites to add to my dj drops?
