Help needed for basic editing question.
Help for Audacity on macOS.
swami7774
Post by swami7774 » Fri Jun 19, 2020 5:51 pm
If I want to remove a section from a track, how can I enter an “in” and an “out” mark without holding the mouse down and dragging all the way through the track to the preferred out? I’ve never been able to figure that out. Thanks in advance.
Trebor
Re: Help needed for basic editing question.
Post by Trebor » Fri Jun 19, 2020 6:18 pm
If I want to remove a section from a track, how can I enter an “in” and an “out” mark without holding the mouse down and dragging all the way through the track to the preferred out? ...
Can insert splits at the in & out points,
then double click on the now isolated middle section to select it, then hit delete.
swami7774
Post by swami7774 » Fri Jun 19, 2020 6:32 pm
BINGO. Thank you! This is exactly what I was looking for. Wish I’d asked years ago.
