How to make one track play through both channels?
Help for Audacity on macOS.
bythecshore
Post by bythecshore » Fri Jun 19, 2020 3:03 pm
I have a long recording that has some annoying buzz in the right channel. I'd like to delete that channel and play the left one through both channels. In other words, I want to end up with a mono recording that has the previous left channel now playing through both left and right channels.
It seems like it should be easy to do, but I can't figure out. Can someone tell me how to do this?
Thanks.
billw58
Re: How to make one track play through both channels?
Post by billw58 » Fri Jun 19, 2020 3:27 pm
From the Audio Track Dropdown Menu, choose "Split Stereo to Mono"
Delete the track with the noise using the Track Close button.
-- Bill
bythecshore
Post by bythecshore » Fri Jun 19, 2020 3:46 pm
So simple... thanks!
