Playback with headphones not working
Help for Audacity on macOS.
Eric68
Operating System: macOS 10.14 Mojave
Post by Eric68 » Thu Jun 18, 2020 2:48 am
I am using a MacBook Air (macOS Mojave v10.14.6) and when I playback .aup files to edit them, my headphones/earbuds do not work when plugged in...instead the audio just plays back thru my laptop speakers. I've tried adjusting settings but no luck so far. My endgame is to be able to listen to and edit .aup files thru headphones so no one else in the room has to hear the playback. Any ideas?
billw58
Re: Playback with headphones not working
Post by billw58 » Thu Jun 18, 2020 2:02 pm
Plug in the headphones before starting Audacity. Or do Transport > Rescan Audio Devices.
Are they Bluetooth headphones? Audacity is known to not play well with Bluetooth headphones on Mac.
-- Bill
Eric68
Post by Eric68 » Thu Jun 18, 2020 5:38 pm
Thank you for the reply Bill! I tried both ideas but still just plays on my laptop speakers when earplugs are plugged in. Earplugs I'm using plug into laptop, not bluetooth
Screenshot of what I'm getting
Screen Shot 2020-06-18 at 12.57.08 PM.png (495.82 KiB) Viewed 285 times
billw58
Post by billw58 » Thu Jun 18, 2020 7:00 pm
How do your earphones plug into the macbook? Into the sound output port, or into USB, or some other way.
What is the make and model of the earphones?
-- Bill
Eric68
Post by Eric68 » Thu Jun 18, 2020 7:26 pm
Well magic happens...
To first answer your question...they plug into an earphone port, not usb. I tried again by plugging in my audio-technica headphones this time and then launching Audacity and it worked! Then tried the off the shelf "ear candy" earplugs and they too worked now. ...so not really sure what was the magic bullet but seem to be in business now. I appreciate your time and insight to help. Once again the solve seems to be a simple fix. Until next time...Cheers!!
AbsaChile
Post by AbsaChile » Sun Aug 02, 2020 4:09 am
Do you think it was a matter of the headphones? Because I have the same issue but none of my headphones seems to work.
