Not recording from USB DVD player
Help for Audacity on macOS.
AlanWilson42
Post by AlanWilson42 » Sun Jun 14, 2020 8:06 am
I've followed all the tips & FAQs I can find and still can't get Audacity to record from an external USB DVD player.
Mac OS: 10.15.5
Audacity: 2.3.3
Sharing & Permissions for me are Read & Write
Terminal shows SIP is enabled
With System Output Device as MacBook Pro Speakers, the DVD plays sound, no problems
System Preferences, Security & Privacy, Privacy, Microphone does not list Audacity and, as noted in Help, there is no + to add an application
Audacity has not asked for permission to access the microphone (or anything else
I have tried every combination of the System Output Device, Audacity microphone (2nd drop-down) and Audacity speaker (4th drop-down) from those available: MacBook Pro Speakers, Movavi Sound Grabber, SWB Audio Capture & USB Advanced Audio Device: all give a flat line when recording.
Help!
Re: Not recording from USB DVD player
Post by kozikowski » Sun Jun 14, 2020 8:43 am
Audacity 2.3.3 is a 32 bit app and Mac OS 10.15 forces 64 bit applications. I think it can be forced to work with some tricks.
Screen Shot 2020-06-14 at 1.40.42.png (22.65 KiB) Viewed 81 times
https://www.audacityteam.org/download/mac/
