Label gets inserted when pasting audio with Sync-Lock-Tracks On
waxcylinder
Re: Label gets inserted when pasting audio with Sync-Lock-Tracks On
Post by waxcylinder » Wed Jun 10, 2020 4:34 pm
steve wrote:
Wed Jun 10, 2020 1:25 pm
steve wrote:
Wed Jun 10, 2020 10:38 am
I'll take a look and see if I can work out what fixed it.
It was fixed here: https://github.com/audacity/audacity/co ... b9cc0889b5
That was fixing a closely related bug: "Bug 2408 - A region label gets split on inserting audio when Sync-lock is turned on"
Which was the bug that you found and reported earlier Mike :)
Peter.
Post by steve » Wed Jun 10, 2020 4:55 pm
It was bug 2408
viewtopic.php?p=393083#p393083
mafg1953
Post by mafg1953 » Wed Jun 10, 2020 5:10 pm
I have been using labels quite a bit as I edit audio that comes from 1:30 minute seminars and then send the audio to an audio reviewer - so labels help me organize my processing and are very useful for the reviewer to locate problem areas.
