2.4.1 Screen flashing
Trainer
Post by Trainer » Fri Jun 05, 2020 5:03 am
Greetings
Thank you for the 2.4.1 update, especially the larger timer display.
I have an unusual issue with 2.4.1. (on Windows 10) When I hit one of my short cut keys, especially the numbers, the Audacity screen very quickly flashes to whatever other screens are open (eg: Google Chrome or Explorer) and back to Audacity.
It doesn't affect function, it's just hard on the eyes!
I checked, and I notice version 2.3.3 does not do this.
Thanks for your help.
James the Media Trainer
Re: 2.4.1 Screen flashing
Post by steve » Fri Jun 05, 2020 11:15 am
What does the shortcut do?
Trainer
Post by Trainer » Sun Jun 07, 2020 9:54 pm
Hi.
I checked, and the screen flashing only seems to occur on Noise Gate and Limiter. (I use a lot of Macros, with combinations of effects, so for me it happens very often).
Thank you for any help you can offer.
Kind regards
James the Trainer
Post by steve » Sun Jun 07, 2020 10:50 pm
Do Noise Gate or Limiter cause the problem if you apply them manually rather than in a Macro?
Could you check if other effects that appear "below the line" in the Effect menu (such as "High Pass Filter", "Low Pass Filter", "Tremolo"...)
Trainer
Post by Trainer » Sun Jun 07, 2020 11:22 pm
Hi
The noise gate and limiter effects cause the problem even on their own, even when not used in a macro.
I tried all the other effects in the effects menu (above and below the line) and the screen flash did not occur for any of them.
James
Post by steve » Mon Jun 08, 2020 9:29 am
Is that when running them from the Effect menu rather than from a keyboard shortcut?
Trainer
Post by Trainer » Mon Jun 08, 2020 9:58 pm
Hi there.
It happens when I use keyboard shortcuts, also when I use these effects in macros and also when I use them from the effects menu.
I have attached a short video to demonstrate.
Thank you for your help.
Audacity Help Forum 3-1.m4v
(1.05 MiB) Downloaded 15 times
Post by steve » Mon Jun 08, 2020 11:18 pm
Try the delay effect again, but set "Allow duration to change" to "No".
Trainer
Post by Trainer » Mon Jun 08, 2020 11:31 pm
I changed that over, and made no change. The delay effect does not cause the flash effect, just the noise gate and the limiter.
Thanks
Post by steve » Tue Jun 09, 2020 7:00 am
How about the "Vocal Reduction and Isolation" effect? Try it with "Remove Vocals: to mono" (first option) and "Remove Vocals" (second option in the first control). Do either, or both create the screen flash?
Do you get a screen flash if you use "Tremolo" on a very long track?
