Compressing WAV file to 44.1k?
zenseeker
Post by zenseeker » Sat Jul 04, 2009 10:06 pm
I am trying to upload wav samples into Second Life, however they are larger than the 44.1k limit set by SL. Could someone guide me on how to compress a wav to 44.1k?
Thank you.
Trebor
Re: Compressing WAV file to 44.1k?
Post by Trebor » Wed Jul 08, 2009 10:04 am
You may mean resample to 44100Hz, (not compress).
In Audacity 1.3 "resample" is in the "Tracks" menu.
zenseeker
Post by zenseeker » Wed Jul 08, 2009 6:01 pm
Shows how much I know :lol:
Thank you, I'll give it a try.
Trebor
Post by Trebor » Fri Jul 10, 2009 9:23 am
This "second life" wiki seems to confirm my hypothesis ...
Knowledge Base says, "Valid sounds are any .WAV file in standard PCM format, 16-bit/44.1kHz/mono or stereo (which will be converted to mono anyway), less than or exactly 10 seconds in length. (10.000 seconds is fine, but 10.001 will fail to upload; to the degree of one sample makes a difference.) Sounds cannot be saved as 8-bit, 22.05 kHz, or any other frequency. Sounds in other formats can be converted in most sound programs. An example of a free quality converter is r8brain. There is currently no support for compression formats such as MP3." Another very useful application for converting your sound clips to 44.1kHz .wav format is Audacity
http://wiki.secondlife.com/wiki/Sound_Clips
Geenman
Post by Geenman » Sat May 12, 2012 4:59 am
to convert to 44.1kHz
Open your track
Highlight track and choose edit menu >duplicate
change top track to 44.1 (and delete top track?)
highlight second track
check project rate ( bottom left of Audacity-44.1kHz)
go to top menu "Project" > quick mix
cut any excess off end
adjust volume
save as ...
Post by steve » Sat May 12, 2012 10:33 am
That's rather a roundabout way of doing it Geenman.
The straightforward way is as Trebor wrote: Tracks menu > Resample.
Geenman
Post by Geenman » Sun May 13, 2012 1:09 am
i have Audacity 1.2.6
in the track's drop down there is no "resample"
only "set rate" ..and when i use this, it changes the rate, but the
audio pitch gets tweaked into the unuseable.
If i am doing something wrong, can you plz post how it should be done?
Thanx :)
edgar-rft
Post by edgar-rft » Sun May 13, 2012 8:42 am
Geenman wrote:i have Audacity 1.2.6
Audacity 1.2.x is obsolete since November 2005, the program code of your Audacity version is more than 7 years old!
I don't think that anybody can remeber how this worked in Audacity_1.2.x, because it's too long ago.
Geenman wrote:If i am doing something wrong, can you plz post how it should be done?
Yes, the problem is that you're using an obsolete Audacity version. The current Audacity version is Audacity_2.0. Use Audacity_2.0 and then use "Resample" from the Audacity "Tracks" menu.
- edgar
Geenman
Post by Geenman » Mon May 14, 2012 4:35 am
It's strange.. i downloaded the new Audacity on my other comp,
and then tried to DL the same file on both 1.2.6 & 2.0
the 2.0 didn't recognize the file, but the old 1.2.6 did.
Do i still have to DL the LAME thingy for 2.0 mebbe?
Thanx for any help,
G
Trebor
Post by Trebor » Mon May 14, 2012 10:13 am
Geenman wrote:... the 2.0 didn't recognize the file, but the old 1.2.6 did.
I think you mean FFmpeg ...
FFmpeg 0.6.2 for Windows and Mac listed below should be used with the latest version of Audacity
http://manual.audacityteam.org/man/FAQ: ... Library.3F
[ LAME is not required to play audio files, but is required to export (convert) files to MP3 format ]
