System has been working fine until this morning ... now when I attempt to record, there is little or no visible sound track.
I'm using a ProFX mixer, if that info is of any help
Recording Volume
Re: Recording Volume
More on above issue: I recorded a short track (invisible to the naked eye) and did an RMS check and it showed -65
