Debug report
lari5567
Re: Debug report
Post by lari5567 » Thu Jun 04, 2020 6:33 am
I keep getting the same "debug report"
Re: Debug report
Post by steve » Thu Jun 04, 2020 10:49 am
Please attach the full debug report. The message window tells you where the report file is located ("C:\Users\asira\....")
lari5567
Re: Debug report
Post by lari5567 » Mon Jun 08, 2020 9:50 pm
I get the same exact debug report, nothing changes at all
BrianGygi
Re: Debug report then shut down
Post by BrianGygi » Mon Jan 25, 2021 10:16 pm
I am having the same problem. I downloaded Audacity 2.42 for Windows 10, and when I run it the startup screen comes on, but if I try to do ANYTHING, the debug report screen appears. I went to the log file, and here are the problems. HELP!
15:38:36: Audacity 2.1.3
15:38:36: Trying to load FFmpeg libraries...
15:38:36: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
15:38:36: Looking up PATH environment variable...
15:38:36: PATH = 'C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Users\Brian\AppData\Local\Microsoft\WindowsApps;'
15:38:36: Checking that '' is in PATH...
15:38:36: FFmpeg directory is in PATH.
15:38:36: Checking for monolithic avformat from 'avformat-55.dll'.
15:38:36: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
15:38:36: Loading avutil from ''.
15:38:36: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
15:38:36: Loading avcodec from ''.
15:38:36: Loading avformat from 'avformat-55.dll'.
15:38:36: Error: Failed to load FFmpeg libraries.
15:38:36: Error: Failed to find compatible FFmpeg libraries.
15:39:32: Error: File 'C:\Users\Brian\AppData\Local\Audacity\SessionData\project28123\e00\d04' couldn't be removed (error 5: access is denied.)
15:39:32: Error: File 'C:\Users\Brian\AppData\Local\Audacity\SessionData\project28123\e00' couldn't be removed (error 5: access is denied.)
15:39:32: Error: File 'C:\Users\Brian\AppData\Local\Audacity\SessionData\project28123' couldn't be removed (error 5: access is denied.)
Re: Debug report
Post by steve » Mon Jan 25, 2021 10:29 pm
Are you are logged in as "Brian"?
Check the folder: "C:\Users\Brian\AppData\Local\Audacity\SessionData\" and ensure that you can read and write to it.
BrianGygi
Re: Debug report
Post by BrianGygi » Tue Jan 26, 2021 10:27 pm
There is no directory 'C:\Users\Brian\AppData\Local\Audacity\SessionData\project28123.' Should I create it? And yes am logged in as Brian
Re: Debug report
Post by steve » Wed Jan 27, 2021 10:12 am
That explains why Audacity can't read from it.
Should I create it?
No. That won't fix anything because you would also need to recreate all of the files that were in that folder.
Reboot your computer, then:
Open the hidden folder:
Code: Select all
Users\\<username>\\AppData\\Roaming\\audacity\\
and delete these three files:
  • audacity.cfg
  • pluginregistry.cfg
  • pluginsettings.cfg
jademan
Forum Crew
Re: Debug report
Post by jademan » Wed Jan 27, 2021 6:42 pm
You may not be able to view the AppData directory because Windows hides it.
To make AppData visible, in File Explorer, click on the View tab, then check the box labelled "Hidden Items".
I hope this helps. :D
BrianGygi
Re: Debug report
Post by BrianGygi » Wed Jan 27, 2021 8:12 pm
Hi Steve and Jademan,
Thanks for your responses. I made those hidden files visible, and there is a directory C:\Users\Brian\AppData\Local\Audacity\SessionData but there is nothing in it. I deleted those files you suggested, Steve, then tried running Audacity, and got the same error, and those three files were recreated.
What now?
Thank you again for your help,
Brian
Re: Debug report
Post by steve » Wed Jan 27, 2021 8:41 pm
As a test, see if you can create a new file ("untitled.txt") in the folder "C:\Users\Brian\AppData\Local\Audacity\SessionData"
