HI there everyone,
Am using Mac OS High Sierra VERSION 10.13.6. I just installed Audacity 2.4.1 & I added the GSNAP plug in. I enabled it in the effect and all that but its shown blank as you can see on the screen shot below.
Here is the screenshot how GSNAP is popping-out . Please do let me know if am missing something. Thank you.
GSNAP ENABLED BUT SHOWS BLANK POP-OUT
Hanabanana
- Attachments
- Screen Shot 2020-05-26 at 11.36.58 AM.png (102.89 KiB) Viewed 204 times
Re: GSNAP ENABLED BUT SHOWS BLANK POP-OUT
Try disabling the "graphical display" (this replaces the non-working pretty GUI with a basic GUI).
To do that:
1) Click on the hamburger button in the bottom left of the effect.
2) Select "Options", then
3) Remove the tick mark from "Enable graphical interface"
4) Close the effect window.
When you reopen the effect, it will hopefully have a usable (but ugly) graphical interface.
To do that:
Hanabanana
Thank you so much. It worked.
