Playhead is missing in 2.3.3 / 2.4.1
Please state:
monochromec
Post by monochromec » Mon May 25, 2020 6:00 am
The little green arrow (aka playhead/recordhead) is not visible during playback / recording in 2.3.3 (cf. https://bugs.launchpad.net/ubuntu/+sour ... ug/1877833). Installation is from standard Ubuntu repo.
This bug can be reproduced on FC 32 running Plasma 5.18.5.
My initial assumption that this is a GTK3 packaging issue doesn't seem to be valid as this bug is reproducible across distros and Audacity versions. It also manifests itself in custom builds of 2.3.3 and 2.4.1 on Ubuntu using GTK3.
More than happy to provide more information - just let me know.
Re: Playhead is missing in 2.3.3 / 2.4.1
Post by steve » Mon May 25, 2020 1:36 pm
As it says in the bug report, it may well be a GTK3 issue. The current version of Audacity should be built with GTK2.
I believe the Audacity developers will be migrating to GTK3 for the next Audacity release (2.4.2).
Post by steve » Mon May 25, 2020 1:38 pm
Perhaps you could try building Audacity 2.4.1 with GTK2 and see if that fixes it for you (It works for me).
