Opening another file with mac version 2.4.1
kc59harley
I wanted to let you know that there is a bug in the current version 2.4.1 as it was in 2.4.0. The issue is if you have a file already open and try to right mouse click to open another audio file with either versions, it won't. You have to go to the File, Open from the app to get the new file to open to edit. For me anyway it's cumbersome to do that since I create radio shows and have to put liners and or promos in between segments. Also I'm using a Mac with Catalina as the OS.
billw58
Re: Opening another file with mac version 2.4.1
This has been logged as bug 2437.
-- Bill
-- Bill
