Audacity 2.4.1. won't start
frkotou
Post by frkotou » Sat May 23, 2020 2:30 pm
Hi, I have a problem with new audacity version: 2.4.1. When I start audacity, the logo appears for a while, the application doesn't start. In the task manager I see that the exe file is running, but nothing is happening. The previous version 2.3.3 worked, but I want a new one. I have Windows 8.1. On another PC with Windows 10, audacity 2.4.1 works great.
Re: Audacity 2.4.1. won't start
Post by steve » Sat May 23, 2020 3:35 pm
Try running the installer again, and select the option to "Reset Preferences" when it appears.
Resetting preferences "may" fix the problem - let us know what happens (I can't test myself as I don't have Windows 8)
frkotou
Post by frkotou » Sat May 23, 2020 3:45 pm
I tryed it, but no changes.
