Hello,
I know that I read something about a change to the Noise Gate plug-in for Audacity but I can't seem to find that post. After installing 2.4.1 I now have two active versions of noisegate.ny. They seem to be the same but have different parameter settings. I have tried both and they work, but which to disable? I have included a screenshot of my plug-in page to show their installation path.
Any help would be welcome, also a link to the changes made to the plugin.
-Ron
Noise Gate - V2.4.1
Rontro809
Noise Gate - V2.4.1
- Attachments
- Screenshot of my Plugin Install list
- Screen Shot 2020-05-21 at 9.45.20 AM.png (745.99 KiB) Viewed 142 times
Re: Noise Gate - V2.4.1
Disable the one in "/Users/..."
To check that I've said the right one, open the remaining Noise Gate effect and click on:
"Manage button > About"
and it should say:
"Version: 2.4.0" (that's when it was last updated).
and it should say:
Rontro809
done and thank you!
-Ron
-Ron
