Autotune plugin installed and seemingly working, but not visible to use properly
Help for Audacity on macOS.
jmhughes2102
Operating System: macOS 10.14 Mojave
Post by jmhughes2102 » Wed May 20, 2020 12:02 pm
Hi, I hope someone can help.
I am running audacity on Mac OS Mojave and have just installed two Autotune plugins, Graillon 2 and Gsnap.
They seem to be working, but not visible when I select the plugin, Screenshot below:
Screenshot 2020-05-20 at 12.59.02.png (623.23 KiB) Viewed 49 times
If I select things from the settings it works, but there is nothing visible on to be able to use it properly.
This may be a silly question, but I'm not very clued up so any help would be much appreciated.
Thanks in advance!
Jsh
Re: Autotune plugin installed and seemingly working, but not visible to use properly
Post by steve » Wed May 20, 2020 12:21 pm
Antares Autotune does not support Audacity.
A list of supported "host" applications is available on the Antares website: https://www.antarestech.com/host-daw-compatibility/
