my microphone no longer works on audacity
Help for Audacity on macOS.
chiomaVO
Operating System: macOS 10.14 Mojave
Post by chiomaVO » Tue May 19, 2020 11:42 pm
Hello.
I have a Macbook Air, Mac0S Mojave
I use Audacity 2.3.3 and my microphone is the Snowball Ice.
Recently, every time I plug in my microphone on Audacity it doesn't work. Instead, the following text appears:
"Error opening recording device.
Error code : -9997
Invalid sample rate "
This has been really demoralising so please, if you know how to fix this help is very much appreciated.
40robH
Re: my microphone no longer works on audacity
Post by 40robH » Wed Jun 10, 2020 1:44 pm
Hi
I have exactly the same issue.
Catalina 10.15.4
Audacity 2.4.1
Macbook Pro
9997 Sample Rate
I was working on a song yesterday - all OK
Today I have the above error when I select "USB pnp sound device" whether or not the Rode NT3 mic with Citronic XU60 A to D converter is actually plugged in.
Works OK on MacBook microphone.
I have changed nothing.
Did you find a solution to this?
Thanks
Rob
Post by kozikowski » Wed Jun 10, 2020 4:14 pm
Did all y'all Zoom between those times? Zoom, Skype and the other communications programs take over and can reset your microphone and sound systems.
