Help editing an audio
Help for Audacity on macOS.
stephenmkirk1
Post by stephenmkirk1 » Sun May 17, 2020 11:24 am
Hello,
Can some kind soul help me?
My wife and I can hear a ticking sound in our flat at night which we would like to send to the managing agent to investigate.
The ticking is very faint but disturbs us at night because it is directly behind our bed head.
I have recorded the sound (attached) and if you listen carefully you can hear the ticking but I can't find a way to clear the hissing so the ticking is more audible.
The clip is 21 seconds long but I just need a few seconds sample.
I have tried using Audacity and it seems to have the right tools but I'm getting nowhere as
20200517-062405.wav
(904 KiB) Downloaded 12 times
a novice.
Can anyone more proficient kindly edit the audio so the ticking is clearer?
Thanks so much!!
Stephen download/file.php?mode=view&id=27199
Trebor
Re: Help editing an audio
Post by Trebor » Sun May 17, 2020 12:47 pm
Maybe an old electromechanical electricity-meter, or timer : it's ticking every 240ms ...
waveform & spectrogram in Audacity
stephenmkirk1
Post by stephenmkirk1 » Mon May 18, 2020 9:02 am
We doubt it that's because it only started a few weeks ago and we've been here for 15 years. Have you tidied up the sound? If so how do I download it.
Thanks so much!
Stephen
Reason: email remaoved for user's protection from spambot harvesting
Trebor
Post by Trebor » Mon May 18, 2020 11:10 am
20200517-062405, before-after.wav
"after" is LOUD
(1.95 MiB) Downloaded 6 times
20200517-062405, before-after.png (780 KiB) Viewed 68 times
stephenmkirk1
Post by stephenmkirk1 » Mon May 18, 2020 11:32 am
brilliant - thanks so much!
