auto stop of audacity recording
Please state:
xuengiep
Post by xuengiep » Wed May 13, 2020 1:13 pm
Hello
I am using ubuntu 18.04 64 bits and audacity 2.3.3 provided by official ubuntu software resources.
I have used audacity previously without trouble with other version of ubuntu.
Presently when I am recording from my usb microphone my acoustic guitare , the recording stop at any time without touching any thing.
I disable " sound activated recording " the level of which being at -50 db.
software playthrough of input is ON
Detect dropouts is ON.
I looked the manual and forum but did not find any clear answer . Is any one ? some suggestion to
understand the problem ? I's really annoying .
Thank you to help me to understand and overcome this problem.
albuntu
Operating System: GNU/Linux other
Re: auto stop of audacity recording
Post by albuntu » Thu Apr 15, 2021 11:10 am
I have the same problem (Manjaro 21.0, 64 bit, Audacity 2.4.1): Recording stops at any time (mostly within 8 minutes) when "software playthrough" is enabled.
Until now I found no solution except using 'ocenaudio' - here is the monitoring of the input signal full functional.
Post by steve » Thu Apr 15, 2021 1:34 pm
"Sound activated recording" is disabled by default. Might you have inadvertently enabled it instead?
jademan
Forum Crew
Post by jademan » Fri Apr 16, 2021 12:23 pm
Windows guy here. This thread looks similar and provides a possible solution: Can only record one track
Hmm... also, I wonder if a sample rate mismatch could cause this problem...
