Windows 7
2.3.3
Just switched from 2.2.2 to 2.3.3 and my track height isn't being saved. In the previous version I could manually resize a track, save the project and when it was reopened the track height was the same. Now they all return to some default value upon opening the project. It wouldn't be as bothersome if there were a way to collapse selected tracks, but it's either all or nothing, am I right?
Track height not saved.
Re: Track height not saved.
Grab the bottom border of the track and push?
waxcylinder
Sorry, this is a bug that we have fixed for the upcoming 2.4.0xerkon wrote: ↑Sat May 09, 2020 1:35 pmWindows 7
2.3.3
https://bugzilla.audacityteam.org/show_bug.cgi?id=2265
Track heights are reset to default on project re-opening
This was a regression on 2.3.2 and earlier which inadvertently got made in the 2.3.3 development cycle and sadly was not spotted until after 2.3.3 was released.
Peter.
OK, thanks for the help, Peter!
